12 posts / 0 new / Last post
#1  June 27, 2018 - 10:02am
Grifone1893's picture
Offline
Kudos: 0
I have auto update apps on, I try to turn it off and I made a manual search on app store but no update is available.
Is it normal? Someone have already receive it?
  June 27, 2018 - 10:56am
OlivierQC's picture
Beta Tester
Offline
Kudos: 1
I made the update on the app store
Egreat A11, Zidoo X20 PRO and Apple TV 4K with the great Infuse PRO
  June 27, 2018 - 11:24am
Offline
Kudos: 0
I tried too, but no update available...
  June 27, 2018 - 11:35am
NC Bullseye's picture
Moderator
Online
Kudos: 352
Are you looking under the "Purchased" tab?
Or are you just searching under the main app store?
You will get the "update" button if you use the purchased tab.
•Just Another Infuse User• •Not An Employee Of Firecore• •Certified Curmudgeon•
  June 27, 2018 - 11:55am
Offline
Kudos: 0
I searched under the main app store, I don't know why Infuse doesn't appears under the purchased app. (i have the 1 year subscription)
  June 27, 2018 - 12:58pm
Moderator
Online
Kudos: 352
Are you looking for Infuse or for Infuse Pro under your purchased tab?
Try going to the App Store > Purchased > Entertainment
That is where both Infuse 5 and Infuse Pro 5 will be categorized (both will only appear if you have purchased both, normally only one will be there).
Then just click on the Infuse Icon for Infuse 5 (Infuse Pro 5 isn't a subscription version) and it should have an update button there.
  June 27, 2018 - 1:18pm
Offline
Kudos: 0
Thanks fo helping, but, Infuse doesn't appears in any category. (Checked and double checked)
It's strange because it's the first time it happens. Older update always worked fine (update automatically)
  June 27, 2018 - 1:41pm
Moderator
Online
Kudos: 352
Sounds like you may be logged in under a different apple ID. Do you have any other Apple IDs for the app store?
Is this a shared app with family sharing by any chance?
  June 27, 2018 - 2:30pm
Offline
Kudos: 0
No and no.
I don't want to make another install (I have had the icloud bugs in past days..i've had eneough of rebuilding metadata)
  June 27, 2018 - 3:50pm
james's picture
Staff
Online
Kudos: 1,099
What do you see if you search for Infuse in the App Store?
Can you check the version you have installed by scrolling to the bottom of Infuse > Settings?
If you don't see Infuse 5 in your purchases list, then you may also try logging out of the App Store, restarting the Apple TV, and then logging back in. This can often times clear up App Store wonkiness that appears from time to time.
Infuse 6 for iOS and Apple TV is now available!
  June 27, 2018 - 10:09pm
Offline
Kudos: 0
Thx James, I'll try.
At the bottom of Infuse settings I see "Infuse pro 5.7.3"
  June 27, 2018 - 10:31pm
Offline
Kudos: 0
Update:
James, it worked! After logout/login Infuse update itself...Thx
The only wierd thing is: under purchased app, Infuse doesn't appears.
