As I remember you needed just ssh root access as you can deal with that from there, so what the problem if you have it already ? Why do you need atvflash now?
[quote="MightyJew"]
Don't be a hole. I understand that. Then why hasn't seasonpass put out a jailbreak for ssh access at the least, I can deal with that from there.
[/quote]
[quote="carls.8251"]
by the way how are you going to install xbmc or other applications on new interface if you would have jailbreak today
[/quote]
[quote="MightyJew"]
I did successfully JB my 5.1, injected ssh and now see the root. All i am waiting for is firecore flash, unless i can install xbmc command line which i am about to try. not sure what the outcome will be but i will soon find out.
[/quote]
Are you serious? Why would I want atv flash? dude you are really off your rocker. atv flash is the ■■■■ for adding all the options. i am just waiting for the new version now to install. since you are an idiot, 5.1 is a completely different version from versions 4. So once firecore has a ready version or puts out a beta, I cant really do anything. XBMC isnt jiving with 5.1 or at least i cant install it right. Thank god for brains or i would have never jailbroke 5.1 on the A4. Thanks for nothing losers. I jailbroke my 5.1... its okay to be jealous.
